Charging deep cycle batteries is a science. Consider this report from Progressive Dynamics on how long it takes to re-charge a deep cycle battery using the DC Charging voltages that come from SmART MODE Converter/charger units.
"Progressive Dynamics ran this test on the amount of time it took a PD9155 (55-amp) converter/charger set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
13.6-VOLTS (Normal Mode) – Required 40-hours to return the battery to 90% of full charge and 78-hours to reach full charge.
13.2-VOLTS (Storage Mode) – Required 60-hours to return the battery to 90% of full charge and 100-hours to reach full charge."
What you must do is come up with the smart mode charger that will handle these DC CURRENTS for each battery in your setup being charged. The rule of thumb is a single battery will demand around 15-18AMPS DC when hit with 14.4VDC charging voltages for the first 15 minutes or so and then start dropping off as the batteries start taking on charge. My battery bank will settle down to around 8AMPS DC current draw after two hours of 14.4VDc BOOST charge mode. Then the smart mode converter/charger will switch down to 13.6VDC and continue charging for an additional hour. The battery bank is drawing around 6AMPS of DC current during this one hour period of time. After the total three hours of smart mode charging my battery bank will come to around the 90% charge state.
If you do not have the higher Charge CURRENTS available the battery banks will attain a full charge state but will take many hours of charge time. If your highest DC voltage is going to be 14.4VDC then around 15AMPS per battery is all that is required. The battery determines how much current it wants to see so having a 300AMP DC CURRENT will not make charging any faster per say. The battery will only demand 15-18AMPS of DC CURRENT from your converter/charger unit for the one battery. Two batteries 30AMPS - Four batteries 60AMPS etc...
If you have two 6VDC golf cart batteries in the setup these will be considered one 12VDC Battery so the 15A-18A rule of thumb applies for the two 6VDC batteries connected in series.
I use the PD9260C converter/charger here mounted stand alone close to the battery bank which needs around 120VAC@1000watts to operate it which my 2KW Honda EU2000i generator runs it just fine... I haven't checked but I don't think I can run a PD9280 at full charge BOOST mode from my 2KW Honda generator.
This is a simple drawing of my four 12VDC batteries connected in parallel is setup
I am currently only using three GP24 12VDC Interstate batteries in my bank
My DC BATTERY MONITOR Panel setup looks like this on the inside of my trailer for me to view what is going on.
Have been camping off the power grid since 2009 with this setup and are very successful
Just some of my thoughts
Roy Ken
