MEXICOWANDERER
Sep 29, 2019Explorer
- If the rig's rear bumper sags more than four or five inches between loaded, not loaded add more leaves to rear springs. If the complaint is excessive leaning around curves a rear sway bar will help. a bigger front sway bar will further improve stability
- As noted the best-rated shock absorbers are a must:I like KONI but maybe there isn't a number available
- Maybe after these upgrades you won't need the steering fixes
