Itinerant1
Mar 03, 2019Explorer
I don't take post as confrontational, it's the internet and sometimes typed words come across flat without emojis, it happens. But that's why we have these forums to help clear up some of the mud that gets stirred up. ;)
Yes, I fulltime in a 5th wheel traveling the western states (30k miles). Have boondocked not paying for camp spots 1,035 days out of the past 3 years with approximately 350+/- cycles on the batteries. Moving with the weather but can be at elevation with colder temps 30f - or places that are 90f +. I don't like either extrem but certainly don't worry about it.
My particular setup is in the front compartment of the 5th wheel. It is unheated and is somewhat open to the outside. What I did was bought a 4x8 sheet of the rigid foam board and cut pieces to fit in the sections of between the frame structure. One piece was cut to fit a 18"×12" opening that can be removed in warmer weather for better air circulation. Doing this has helped in colder weather retaining some heat in the compartment. I do carry a small cube heater that I can plug in that compartment if I was really worried about it.
The reason for the "technical" reply was so folks can understand more of the temp/ battery than the generic respone which is repeated like gospel about charging at sub 32f. Yes ambient might be that but not the lfp cells themselves. Once again I will say that's why being able to see individual cell info is important.
So it's cold where you store it. An lfp battery should stored at 50% +/-, start using the battery it will start warming itself plus having an insulated compartment or some sort of wrap and a warming pad for the batteries... issue solved. Or take them with you.
The heat thing, even with ambient above 95f my 20 cells have never been above 85f. Or below 44f. This is from experience living off of solar/ lfp and I do basically live like being plugged in.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
