- wa8yxmExplorer IIIGoogle, or in this case Yahoo, is your friend:
Search term: pinesol formulation
Found it contains two forms of Alcohol
Alcohol vapors are explosive and since the proper name of the Propane Detector is "Explosive Gas Detector" yes they will set it off.
how explosive are there... Trust me you do not want to know.. I do, but it was pure wood alcohol, used to fuel a space heater, that blew up in my fact, not the diluted formulation Pinesol uses.
(Thank heavens there was a handy snow bank to roll around in or the burns would have been much, much, worse).
But the bottom line is yes,, Pinsol acn indeed set it off. - SCVJeffExplorer(dup)
- SCVJeffExplorer
riven1950 wrote:
and the neighbors ripe trash in the summer...
Add raid bug spray to the list - riven1950ExplorerAdd raid bug spray to the list
- Boon_DockerExplorer IIII think you will have a tough time finding a battery operated propane alarm. You can buy a hard wired one from Camping World for a little over $50.
- traindriverExplorerMy alarm says it is worn out after 5 yrs. If I bought another like it to replace it, it would cost $130.00. I can buy a battery propane and co2 alarm for a lot less money. My question? Would you replace yours with a battery model or with the wired in model? My house alarms are battery and they work just fine.
- RJsfishinExplorer
Mandalay Parr wrote:
I fixed mine. I stopped cleaning!
I fixed mine, I stopped detecting ! - Johno02ExplorerPropane alarms tend to get a bit oversensitive with age. Might need to be replaced.
- joebedfordNomad IIIDon't do this:
- light a match to see if it really is propane - 3oaksExplorer
I like your fix. :B
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
