aruba5er
Jun 07, 2013Explorer
Those little auto reset breakers can go bad. Check continuity with a ohm meter. or check volts with a vom . one lead to ground and other to either side of "Shortstop" should be volts to ground on both sides. Your convertor may have an internal fuse you don"t see. If nothing at shortstop go into the convertor. Mine has a glass fuse on both the 120 side and 12 volt side.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
