ken_burke
Jun 08, 2013Explorer
tom496 wrote:
There is continuity across the "shortstop" fuse.
I am getting 13.42V at the posts in the electrical panel where the cables from the converter are connected. I will try to post a photo.
Well you could have a bad converter. The 12 volts you are reading could be coming from the TT battery while the converter is not putting out.
If you can, disconnect the 12 volt batteries. Turn on some DC loads, i.e. lights. If the converter is working you will have DC voltage. If nothing is working the converter is shot.
I hade had a converter that worked part time, but not when a lot od DC devices were connected.
If it is a bad converter, they are not that hard to replace.
ken
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
