Wayne_Dohnal
Jun 21, 2014Explorer
I did a gasoline vs. propane load test on my tri-fuel eu2000i this morning. With a small load (400 watt oil filled heater) performance was the same. With a medium load (400 watt heater plus hair dryer on low, 1375 watts) performance was the same. With a heavy load differences appeared. Switching the hair dryer to high, on gasoline, the voltage was 114.7, watts 1890, and amps 16.2 (kill-a-watt readings). On propane, the initial performance was the same but after a couple of minutes it tapered off to a sustained 111.4 volts, 1755 watts, 15.65 amps. There are so many variables involved that all I'd conclude is that the maximum power output is degraded "a little bit" with propane. I wouldn't take this as a blanket statement, rather as a single data point, and it of course applies only to the eu2000i.
Working against the eu2000i today is that I'm at 3,500 feet. In its favor, it was a cool 60 degrees. I know from prior experience that if it was 90 the generator would not have powered the heavy load on gasoline. Just one of the many variables.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
