SoundGuy
Jun 09, 2018Explorer
MrWizard wrote:
Your house 12v is close to 15v or above
You have an A.C. Voltage ripple in your house 12vdc
Meaning your converter is failing
Easy to check - just turn off the converter and run off the battery, if the noise disappears then the converter is likely the culprit.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
