Kach's avatar
Kach
USB Outlet problems
Our Open Range trailer came with multiple USB outlets installed. They only work intermittently with 1 or 2 cords we have (most do nothing). When it does work, the LED lights in the trailer flicker annoyingly.
I’m hoping I can just wire in some higher quality units in their place. They screwed the outlets into the luan board and the screws just strip out when removing a cord. My wife used command strips to re-attach the plug and it’s holding fine now so that’s probably how I’d re-attach new ones.
Anyone have experience with this? Is the flickering lights a ground issue that goes beyond the outlet itself?
Worst case scenario I’m going to wire in a fuse block and at least put a few high quality units into the master bedroom area for our charging needs.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
