MikeInOregon's avatar
MikeInOregon
Use inverter to power electrical outlets
I'm in the process of purchasing an Outdoors RV Creekside 20FQ. I'm having the dealer add a few things such as a 150 watt solar system and a Go Power 600 watt inverter. I will have two Lifeline AGM 6 volt batteries with 220AH. I would like to mount the inverter in the pass-through area near the batteries and then add a 30 amp plug to the output of the inverter. When dry camping, the shore power cable will be plugged-in to the inverter to supply power to the electrical outlets in the trailer. When running the inverter, the converter will be turned off, the fridge and water heater will be on propane.
I have looked at the two AC appliances that we might use and each one is 200 watts or less and would only be used for a few minutes each day. We would not have more than one appliance turned on at the same time. Other usage would be to charge cell phones or a laptop computer.
The dealer is saying that I will quickly run out of battery power by plugging the shore cable into the inverter. I don't understand why because the only AC power consumption will be the appliances plugged-in to the outlets. The dealer says that the only way they will do this type of modification is if I have four 6 volt batteries with a 2500 watt inverter.
Am I misunderstanding something? Can I supply power to the trailer's electrical outlets as described above?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
