DrewE
Jan 13, 2015Explorer III
If you leave the inverter on for long periods of time (even when it's not powering anything) it will consume a nontrivial amount of power... 0.9A if it's their pure sine wave model, or 0.2A if it's their modified sine wave model, according to the Go Power website. For charging cell phones, you're likely better off using a 12V car charger than a 120V charger powered by the inverter.
Other than that, you should be OK. You are probably losing some power to unnecessary "phantom loads" such as the microwave clock (assuming you have a microwave), the TV's standby power supply (assuming you have a TV), etc. For relatively short-duration usage, they're probably not worth losing sleep over.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
