MEXICOWANDERER's avatar
May 30, 2016
Use Local Voltage To Sense Remore Voltage (Meter)
http://www.buyincoins.com/item/26013.html#.V0yNGeSG9_k
This link takes you to an accurate digital voltmeter. One of the problems with using a remote mounted meter, is that it reports what it see's, no matter how severe the voltage drop. This meter uses local power to light the LED segments, and remote sensing to read power AT THE BATTERIES. Or panels (to 33 vdc) or converter, or inverter input, alternator output stud, ignition feed, or whatever you wish to monitor.
This critter makes an utter laughingstock out of the "accuracy" of 3-1/2 digit voltmeters.
Sure it's expensive - way beyond the reach of most of us. But when money is no object...
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
