beemerphile1
Nov 06, 2013Explorer
I have enough 10 gauge cord to run from the RV to the house. I take the power straight from the 3,600 watt Onan.
When it gets to the house, I have a home made splitter into two 15 amp circuits. I used a J-box, two 15 breakers, and two 15/20 amp duplex.
I did a little mod to my home forced air furnace. It was initially hardwired but I changed it to a plugin. Now I can unplug from house power and plug into generator power.
I run cords to the refrigerator and two freezers as needed. None of them need to be powered 24/7. I can also run a cord to the entertainment center or other loads as desired.
Of course I also have 3 portable generators to be used as needed.
If you want to rely on your generator as backup power don't forget fuel. In a power outage or disaster fuel may not be available. I keep two 15 gallon drums of gasoline in the garage treated with Stabil and replenished once per year at least.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
