Ductape
Oct 24, 2017Explorer
Temps will vary a LOT depending on speed and ambient temps. I've seen 150+ but 120ish is typical. What you are looking for with temps is the outlier. One tire much hotter than the rest. Ten degrees variation is common. Inside duals run a bit warmer than outside. Sunny side runs warmer than shaded side. On a crowned road the right side will run a bit warmer too.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
