GordonThree
Apr 30, 2018Explorer
ependydad wrote:
My concern with re-using wrecked packs is not knowing what kind of internal damage they might have ESPECIALLY after reading about this golf cart battery fire/explosion on the Escapees forums:
http://www.rvnetwork.com/topic/130707-trailer-fire-need-some-help-please/?do=findComment&comment=936293
Definitely not something to take lightly, and without some technical understanding.
If I were to do it:
1. The pack would be fully disassembled, down to it's smallest module size.
2. Each module would be checked to see if it's in-spec in terms of voltage, and for signs of physical damage.
3. Each module would be charged stand-alone, outdoors, to full capacity, and then drained to 20%
4. Modules would be assembled to achieve target voltage / current, and then charged as a pack, outdoors, and then drained, as a pack to 20%
5. A BMS with over discharge, over charge and temperature monitoring would be employed.
Only then would I be comfortable putting pack built from a wreck into service.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 12, 2026
