clarinet
Jun 29, 2015Explorer
I made one small error in my post. You do not use the ground wire. What you need to do is get a piece of 18 gauge thermostat wire and connect it from the "G" on the thermostat to the center/neutral pole on the rocker switch. By the way you can get the rocker switch from the GoRving parts catalog on line. Good luck. Saves a little bit of money.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
