canoehenge1994's avatar
Aug 21, 2014
Using AVgas in your small engines
Curious as to others experience using Aviation gas 100LL which is a low lead 100 octane fuel. I have been using in all my small engines; lawn equipment and generators, for some time with excellent results. I have found it to be stable and easy on fuel lines. MOGAS or motor gas you get at the convenience store pump has 10-15% alcohol which has a propensity for absorbing water and attacking fuel lines and aluminum components. I get mine at the local airport for $5 per gallon, pricy, but, I think the benefits are worth it.
