grizzzman
May 12, 2015Explorer
Well the fact is what have you got to loose? Run em tell they die then replace with a matched set. You will be that much ahead right? Seems it would be a waste if you didnt use both. The capacity is a non issue anyways. The truth is you could put a new set of batteries and have the same issues as pairing used batteries.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
