Poppa_ClayExplorerJun 11, 2013Using Power Inverter to Run Air Con?Is is possable to run the roof air on my MH with an Inverter. I have found a 2000 watt continuous / 4000 watt Peak power inverter and was wondering if it would do the job. I do have a generator and...Show More
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
Related ContentInverter Bad?Inverter install3500w power inverterHow much power does an inverter use?Newbie power question
