Vintage465
Feb 16, 2021Nomad
If you run extension cords to the necessary appliances and use them as required you're good to go. If you want to wire it into a few necessary circuits in your house you need to install a legal transfer switch to prevent back feed into the utilities grid. If you do back feed into the utilities grid you will be going back thru the transformer that feeds your house and re-energizing the primary voltage and endangering the utility companies employees as well as the general public.
