theoldwizard1
Feb 17, 2021Explorer II
time2roll wrote:
3000 watts should run that house fine. Electrician will probably put the critical items on a 120v sub panel in addition to installing a switch and a power inlet to connect power.
3000W is more than adequate to run a typical home that has no 240VAC loads (well pump, electric water heater, electric stove, A/C).
When discussing the connection to your house with your electrician, as about a "generator interlock". A safe solution, that gives you the maximum amount of flexibility of items to power in your house and is lower cost than most "transfer switches".
