time2roll
Feb 17, 2021Nomad
coolmom42 wrote:If that is the case you should not have the huge power requirement but may require 208-230v.
It's a gas furnace with electric blower, in a package unit with the AC, which uses the same blower. I am quite familiar with the utilities in my home.
Generally that will be a dedicated circuit so you could pull the wires off the main panel and extend to a generator running close to the panel.
Yes a transfer switch and all is better but if you need heat on today...
