Gdetrailer
Feb 17, 2021Explorer III
coolmom42 wrote:time2roll wrote:coolmom42 wrote:Is it hardwired? What are the electrical requirements?
I need to run the furnace blower. No way to plug it into an extension cord.
I have a dozen home furnaces and they all plug into a standard wall outlet up in the attic, garage or heater closet.
My furnace & blower are outside in what is called a "GasPack" unit. It's the only configuration of central heat/ac that will work in my 1960s ranch style house with crawl space and low attic space. They are pretty common around here.
Your most likely going to need 230V to run a Gas pack furnace..
Looked up gas packs and found a Goodman 2T with 40K BTU gas furnace and that one requires 208V or 230V for the fan motor..
Found that info HERE
For those who don't understand what a gas pack is they look like this photo for outdoor versions and are "all in one" A/C with gas furnace..
I HIGHLY doubt that it is "plugged in" and most likely is hardwired to at least a outdoor service cutoff disconnect switch..
