ktmrfs
Feb 17, 2021Explorer III
opnspaces wrote:coolmom42 wrote:time2roll wrote:
3000 watts should run that house fine. Electrician will probably put the critical items on a 120v sub panel in addition to installing a switch and a power inlet to connect power.
My generator is 4000 watts. It would be nice to be able to run the whole house, including TV & internet. Not essential, but nice.
Just wanted to touch on this because I had the same thoughts about how cool it would be to keep the internet up. The problem is unless you are tethering the internet through cellular, once the power goes out the internet goes out too. Yes I can get my cable modem back up and running on the generator. But after the signal leaves my modem it is dropped by some unknown system down the line because it has no power either. So in reality once the power goes out the internet goes with it.
in our house if power goes out doesn't mean I loose internet if I power back up the fiber box in the garage and the modem in the living room. Once those are on I have internet. (assuming the intenet/cable hub hasn't gone down.)
