Veebyes
Feb 25, 2021Explorer II
No reason why not. Treat the house like a big RV & be aware of what is on & what is not.
You will need to run a sizeable guage line from the genny to house panel. Connect on the house side of the main panel switch. Make sure that the switch is OFF when on your genny. Trying to back feed the whole grid won't go well at all.
A 3000W genny should power the average home no problem but turn big power hogs such as A/C or electric heat circuits off to be sure. My 3000W portable genny runs everything in my hose just fine, two smallish water heaters & a shallow well pump included. It has been put to good use during hurricane power failures a number of times.
