- Blanco1Explorer
old guy wrote:
you front bumper will more than likely fall off
LOL!!! I doubt it!
- Butch50ExplorerI have used a front hitch in the past with boats and it sure makes it easy to maneuver.
The front hitch on my truck is only rated at 500# tongue weight and 9000# trailer weight. It doesn't take a very big trailer to get to 500# tongue weight than you also have to figure how much capacity you have on the front axle before exceeding the GAWR and tire capacity.
I have a Curt below bumper hitch.
Curt Hitch - midnightsadieExplorer IIdid my boats with front hitch, worked fine.
- old_guyExploreryou front bumper will more than likely fall off
- moebedickExplorerI have a truck camper and often tow a boat. I use my front hitch to launch and retrieve the boat because I can see where everything is and where it's going. It is much easier than backing a trailer that can only be seen when it's at an angle. I am not a novice at trailering since I have nearly fifty years experience. If there is an easier way to do something,and your vehicle is capable of accommodating a front hitch, why wouldn't you use one?
- K_CharlesExplorerYou can see both sides of the TT in the mirrors when backing. You won't see anything with the TT blocking your view.
- IvylogExplorer IIIYou have more overhang off the rear, especially if you add a hitch extension making it possible to make tighter turns BUT it takes more skill than a hitch on the front.
- Blanco1Explorer
Mandalay Parr wrote:
See s to me it would.
Please explain? - Mandalay_ParrExplorerSeems to me it would be easier to navigate with a front hitch. My H2 Hummer had one front and rear.
