swimmer_spe
Nov 19, 2019Explorer
BFL13 wrote:
With the battery not there, collect all the wire terminals that go on its positive post and join them with vise grips or a nut and bolt.
Now the converter will have a path to the jacks. This assumes the jacks are on a different wire that goes to the positive post. Assumes the jacks and the converter each has a negative path to the frame.
I will try that in spring. The trailer is good where it is and I am not running power to it this winter.
My plastic battery box is screwed down, so as long as the +ve does not touch those screws or the -ve wires, I am good.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
