DrewE
Nov 19, 2019Explorer III
mich800 wrote:DrewE wrote:
It depends on the details of how its wired. If it connects directly to the battery (perhaps sharing the connection for the breakaway brake system), then it makes perfect sense. I suspect it is normal for your trailer.
Actually, that seems like a good setup to me, at least in general concept, as it helps to prevent someone from pulling the trailer without a battery for the breakaway brakes.
The breakaway does not work like that. It requires battery power to activate the brakes. And the jacks have a manual over ride. So the lack of battery is probably not a good theft deterrent.
I wasn't meaning as a theft deterrent, but as a bad choice deterrent, though that probably wasn't the clearest from what I wrote. That is, in case someone wishes to move their trailer from here to there but doesn't care to be bothered to install the battery (or replace a dead one), and so pulls it without a working breakaway brake system. Having the electric jack operate in the same way makes that less of a desirable option and so might increase safety.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
