57_Panhead's avatar
57_Panhead
Using to much power?
Prior to purchasing the Winegard carry out antenna we would watch DVDs when not having a TV connection. We would be able to watch 3 or 4 hours before turning it off and going to bed with battery to spare. This last trip was our first with the new Carry Out. After only 2 to 2.5 hours the inverter shut itself off and that was it. We have 2 Interstate 6 volt batteries with rated at 232AH and a Samlex SA1500-12 inverter and a Samlex transfer switch. I didn't think the Direct TV would use any more juice than the Blue Ray player we watch movies on. Any ideas where I may be coming up short here?
The carry out worked great by the way.
Steve
  • RoyB's avatar
    RoyB
    Explorer II
    We use our 255AH battery bank all the time running our home entertainment electronics and several other 120VAC small wattage items from an 600WATT PSW Inverter and 12VDC items direct connected to the battery bank when camping off the power grid. Our big drain is right around 20AMPs of DC current between 8PM and 11PM and then the usual 1-2AMP parasitic keep alive drains the rest of the time.
    This is all planned out to drop our battery bank down to around 12.0VDC at 8AM each morning (approximately 50% charge state) and this is when we re-charge our battery bank back up to its 90% charge state using smart mode charging by running our generator for around three hours each day.
    We do these 50%-90% charge cycles on our battery bank for about 12-14 days without doing harm to our batteries and they will perform to full specs if we re-charge to the 90% charge state each day. If we continue to do the charge and discharge cycles after the 12-14 times then our battery bank start dropping off in performance and will eventually do harm to the batteries. We have to do a good 12-13 hours FULL charge cycle to return the battery bank to a good restored status again. Of course the camp grounds usually don't allow you to run a generator for 12-13 hours straight so this is usually when we plan to go home from our trips.
    We have a good DC MONITOR SYSTEM to monitor what is happening to our batteries as we camp and this really helps us watch things very close so that we don't do harm to the batteries.
    It does take planning to be successful camping off the power grid...
    Roy Ken
  • if those batteries were fully charged ?
    they are toast and you need new batteries
    you didnot say how big your TV is, what is the power use rating, or how old the batteries are
    but 1500w inverter is way over kill for watching TV, meaning the inverter has parasitic overhead that is wasting power, you could be getting by more efficiently with a 300~400w inverter
    232ampHrs at 12v (2*6 in series), that 116 ampHrs to 50% with a 100watt 9.5 amp load that over 10hr
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
