Second_Chance
Aug 17, 2018Explorer II
If you want to go all-electric with your main furnace and keep the basement thawed, this is the way to go:
Cheap Heat
The installation is pricey, but lots of full-timers swear by them. We have weathered stretches of single-digit lows and sub-freezing highs for a week or two at a time (often with 40 MPH winds) on propane heat. We supplement with the electric fireplace and put a ceramic heater on a thermostat in the basement to help, but always make sure the main furnace is cycling. At the worst, we've gone through 30 lbs. of propane in about 3 days.
We use a heated water hose but fill up the fresh tank, disconnect the water and use the pump on the coldest of nights. I wait until sunny afternoons to drain the waste tanks so the stinky slinky doesn't freeze up, too. Reflectix cut to fit in the windows helps if you don't have dual pane windows.
Rob
Cheap Heat
Rob
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
