Lantley
May 19, 2020Nomad
Will the truck stall if you recreate the scenario? If you do a quick u turn will truck stall? If so I would try to narrow down issue to fuel or electric.
Does it stall if tank is full to the top vs. 1/2 empty.
Does it stall if you let off the gas vs. flooring it in the turn?
As someone mentioned any lose wires?
An unreliable tow vehicle is a deal breaker
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
