Gjac
May 20, 2020Explorer III
Oregun wrote:Sounds to me like a failing fuel pump. I spent a lot of time trying to find the problem and changing parts. What I learned from this experience is fuel pressure does not predict a failing fuel pump. If the fuel pump is bad (totally failed) it will but one that is working intermittently testing the volume of fuel(gals/min) is a better test. Have your mechanic look up the specs for your vehicle and have him do a flow test, you don't want to be caught on the road with a failing fuel pump especially in the summer when everyone is traveling and you can't find a shop available to fix it.
My 99 F350/V10 did something similar. Turned out to be the fuel pump in the gas tank.
When it wouldn't start you could hit the gas tank with a board and then it would start.
Or just wait until it cooled off and it would work. Not a cheap repair.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
