time2roll
May 21, 2020Nomad
At 124,000 I suspect the fuel pump has quit. This can be a bit of an intermittent issue for months until it completely gives up. (don't ask how I know) The shop I had took maybe 20 minutes to go down the check list and confirm the pump.
If the plugs have not been replaced ever this would be a good time to get that done too. Consider replacing the ignition coils too if you do the plugs.
