time2roll
May 21, 2020Nomad
ernie1 wrote:This will not create an intermittent problem but the technician should check as part of the fuel pump diagnostics.
For your Ford truck there is an inertia fuel shutoff switch located in the passenger footwell on the right side kick panel that will shutoff the fuel to the fuel pump in case of an accident or sometimes a bump in the road. But if it is triggered, you have to manually reset it by pressing a button and not waiting awhile like you have been doing. Maybe not your problem but I just thought I'd throw it out there for your info.
