time2roll
Aug 16, 2015Nomad
I would eliminate the two posts in the center. Run parallel wire the full length or best to just use a parallel jumper on the battery and single connection to inverter.
Solar can connect anywhere.
300a seems big if class-T for 1/0 or smaller. For single inverter feed I would go at least 2/0 (mine is 6' 4/0) if you need any surge performance.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
