Dennis12
Nov 09, 2016Explorer
I agree with IAMICHABOD. The extenders are nothing but trouble. If your wheels are mounted properly you should only need a good straight pressure gauge with a angle on the back side for pulling back to check pressures inside and out. Take your unit to a good tire shop and let them explain it to you. If you can stay away from the extensions you will be better off.
