Big_Katuna
Oct 06, 2019Explorer II
Or a weak fuel pump. Common problem with 460 s. Once the psi drops below spec the ECM goes wacky and it backfires, pops, etc. If you turn the key off a few seconds then back on it resets until the next time.
What was your fuel level? The fuller the tank the cooler the pump is.
