maillemaker
Oct 07, 2019Explorer
When I was a kid in the 50's, probably half the cars on the road had clothspins clamped on the fuel line to radiate heat from the fuel easing vapor lock.
I have heard of this, and even seen it in a YouTube video, but I find it hard to believe this actually works by radiating heat.
First, wood is not a very good conductor of heat. And even if it was, given the high under-hood temperatures, the result would actually be to wick up heat and put it into the fuel line. This is because heat always moves from hotter-to-colder.
What I suspect is/was actually happening is that wood, being a relatively good insulator was actually insulating the fuel line from the ambient heat in the engine bay. If you clamp a dozen clothes pins onto the fuel line, then all that area is now encased in wood, effectively insulating it.
Carburetor engines often put a phenolic block of plastic between the carb and the intake manifold to try and insulate the carburetor from the heat of the engine.
Steve
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
