time2roll
Nov 11, 2019Nomad
hertfordnc wrote:Are you using the same wires as the 800 watt inverter for the 1500 watt?
Anything else i can look at before i give up?
This same setup will go 24 hours on a very cheap 800 watt no-name inverter.
Otherwise monitor the voltage on the inverter 12v input terminals. You should see 12.2+ volts.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
