garym114
Nov 11, 2019Explorer II
Your battery cables should be at least 4 AWG. Realize that a 300 watt inverter load is drawing about 30 amps from the batteries. You have to have battery cables large enough to carry the inverter load.
At 1000 watts inverter load you will be drawing about 100 amps from the batteries.
You did not say what the battery cable length or AWG size of your battery cable is. Those two make all the difference in inverter performance.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
