wopachop
Jun 18, 2018Explorer
Is that common to switch to a residential fridge? In my brief amount of time learning about RV absorption refers i thought theyre made of steel, no moving parts, and better suited to bounce down the highway compared to a residential fridge.
Any chance someone has a basic spec for how much air would naturally flow through the vents using convention only? I dont have to use a fan. Could vent to the cabin and let it flow naturally. Whats the deal is that a propane hazard? Probably so. Trailer has a propane detector. Should test it with a weed burner.
Or maybe its better to mount a stronger fan outside the rig. Will be blowing 110F+ air, but lots more of it. Will try that method first before cutting into the duct. If we are out there and fridge cant stay below 40F then i might tin snip a hole right there while camping.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
