valhalla360
May 23, 2020Navigator
gbopp wrote:valhalla360 wrote:
when was the last time you saw a car randomly blow up from gas fumes collecting below the car?
You are correct, I have never seen a car blow up from gasoline fumes.
However, I have seen gasoline fumes travel across the ground about 20' and ignite from a fire. I think it's called a flashover? I don't know.
I do know it was scary.
Then a vented box won't solve the OP's issue...doesn't matter if they just have vents on the bottom or also on the side.
Then again, how much fuel was dumped to have enough fumes to travel 20ft and then ignite? Gasoline is a lot harder to light in open conditions than you might think.
