C_Schomer
Feb 22, 2022Explorer
I made a similar mistake with mineral spirits. I was trying to clean every last bit of old caulk off of a small area and the mineral spirits rippled up the rubber membrane. I waited about a week and the ripples flattened out and the membrane look normal. The local trailer repair shop near me told me not to use Hengs and a local commercial roofing supplier told me to use Henry’s. I’ve done two RVs with Henry’s and I pressure washed to remove anything that would possibly break loose and then I used a Scotch-Brite pad and TSP solution to clean the membrane. I used Henry 587 on a previous RV when I lived in the Phoenix area and it still looked awesome after five years of outside storage, when I sold it. I used Henry 787 on this fiver two and a half years ago and it still looks like new, too. If I ever do another one I will use the Henry 887 which is 100% silicon and it is recommended for RVs. I’ve had zero problems with the cheaper Henry products though. Craig
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
