jaycocreek
Apr 06, 2021Explorer II
My battery is rated for 120ah..When I first got the shunt I estimated the SOC because I didn't want to fully charge it after what the battery Bluetooth did..I think I guessed 90% SOC prior to charging to finish the Victron setup...After it was setup,I decided to finally charge the battery with the Noco charger and I could watch voltage off the shunt to make sure the charger was charging correctly,and it did..
Then when it was full or close to,I synced the battery to 100% in the Victron settings..It was today I thought I should take it down from 100% because I'm not completely sure when I can take off fishing..
I started today with a resting 13.59 volts from the day before and ended with 13.28 after it set for 1 hour while I ate lunch..So I used.31 volts for the short time I used it then I had honey do's to do and couldn't finish draining it..
I am just curious if that's in the ballpark of what it should do,after the Bluetooth battery failure, I'm cautiously optimist if the battery is fine...Seeing and following the Noco charger with the Victron,it did nothing out of the ordinary watching every number for two hours..lol
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
