BFL13
Apr 06, 2021Explorer II
With the smart shunt do you see the BMS balancing act before you sync as though "full" ? I think I saw where you do the balancing act and then wait about 20 minutes at Vabs and then declare you are full ? Might not have that right.
If you told the shunt by syncing it a bit lower than full, that might explain why it thinks you have 110AH instead of 120?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
