jaycocreek
Apr 06, 2021Explorer II
I did see the charging voltage climb into the 14's then drop back down into the 13's a couple times and I tried to lookup the reason and didn't come up with anything definitely except cell balancing as the cause..No clue if that's right or not but it finally went into the 14's and stayed there for a short while before the charger stopped and shut off..
I believe my Lifepo4 Expert power 20 amp charger will be here Thursday and I'll use that exclusively on the lifepo4 battery..It charges at 14.4 volts with the lithium profile..I want a quicker charge for boondocking if I need to use a generator and my solar panels can't keep up...
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
