BFL13
Apr 06, 2021Explorer II
20 amps is a low charge rate for the LFP, so on generator you could use way more charging amps to reduce gen time. RV converter plus solar plus 20 amper plus 10 amper. To get the right profile using the new 20 amper, you could use just it for the last bit so it would stop at the right time and the shunt would sync right.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
