roostonu
Apr 07, 2020Explorer
landyacht318 wrote:
Still going, vs still going strong.
One requires No data, experience or knowledge, only pride and ego and ignorance,
The other requires only Data, for points of comparison
YOur rope comment only proves my point about a fragile ego, even though my nimrod comment was directed at battery neophytes on Automotive forums.
Haw haw.
Glad your batteries are still working, but without offering any information on how they've been used, about how many cycles over the subsequent years, and to what depth of discharge, even as a round guestimate, your 'still going strong' report, is basically worthless.
I too saw when these batteries came on the market years ago and wondered about their quality, and your report nearly 6 years later satisfies none of my curiosity.
So give a guesstimate, how many cycles did they accumulate in those 6 years, and to what depth?
My last AGM battery lasted 6 years, but it accumulated well over 1200 deep cycles, about 100 of those well below 50% and many thousands of engine starts and cycles to 90% or higher are not counted towards that ~1200 figure.
I had a nimrod on an automotive based forum say he gets 6 years out of his starting battery for 1/5th the price, implying I am an idiot for having an expensive AGM battery I insure reaches full charge regularly, and he could not seem to realize there is a difference when one is cycled deeply, providing hundreds of KWH over its life, and the other likely never passes 1KWH.
A battery owner on an rv forum is expected to give some information on how the batteries are cycled, you provided NONE just a 'still going strong' claim with Zero evidence that they are still indeed strong.
Your dance around the nimrod comment doesn't work. You compared my post to that of a nimrod's. The piss up a rope comment had nothing to do with my ego and willingness or lack there of to admit I'm wrong. It had everything to do with you comparing me to a nimrod. When you throw comments like that (nimrod and fragile ego) around over a simple comment about my batteries, you are bound to get people like me to tell you to STFU.
You see, I actually agree with you about needing more information but you had to turn your comment into a lecture and scolding for not fulfilling YOUR expectations so now you can just piss up a rope.
For anyone else, I do not have a battery monitor so I never know my state of charge other than battery voltage and I do not care to estimate my charge cycles or DOD so if you want to try and figure it out, go for it. I have two 125ah AGM batteries and a 55w solar panel with PWM controller for our TT. We use the trailer for approximately 4 weeks a year total and it sits the rest of the year float charging from the panel. We have a fridge running on propane, a propane detector and a couple lights left on in the evening until 10:00pm when we are using it. We also charge a phone or two during the day from a 12v port. The voltage is never below 11.5v by the time the sun hits the panel around noon(due to trees blocking the sun). By the time the sun goes down, my batteries are fully charged at 12.6v and my controller goes to maintenance mode. As long as this continues, I will consider my batteries to be going strong, until they no longer do.
