pianotuna
Jun 05, 2013Nomad III
Hi OnaQuest,
I'm sure you did not mean it--but your post sounds a bit aggressive.
Just to set the record straight the Hall Effect meter shows positive and negative flow of amps.
It is rather neat to see the solar system sending energy to the chassis and lowering the load on the alternator.
I already have a volt meter (two, actually). I'm just offering options.
OnaQuest wrote:pianotuna wrote:
Hi,
I prefer hall effect ammeters myself, as no shunt is required.
hall effect
That's your preference, but all you have is an amp meter, for about the same price, where the other meter has the logic behind it to display AH used, Amps flowing, directional amp flow and voltage. Hardly the same function. I prefer shunt based operation.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
