mena661
Jul 05, 2013Explorer
bigcitypopo wrote:4 or 6 ga isn't large enough for a nearly 30 foot or more wire run. The boondocker won't go into boost mode at that distance either. The Progressive Dynamics converters will but you'll have to "force" it via its pendant (and you'll get less charging amps). You CAN move the converter closer, making the 120V cord longer as voltage drop there isn't as significant or important. Doing all that, the WFCO still might not go into boost but other converters definitely will.
I peeked into the panel. It looks like 4 or 6ga to the batteries... So I might be good. I've been looking at the boondock swap outs at bestconverter.com.
I do not want to run heavy gauge to the batteries in a new rig.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
